Is it to late ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2008, 07:40 PM
chevy350_Camd's Avatar
VROOOM !!!!!!
Last journal entry: This is the Rough Draft of the V8 Frame
Is it to late ?
I put my first cam in probably a month ago, and I have started the motor but was ignorant of a break in, its only been started like 10 times and ran for like a couple of minutes each time, Can i still run a break in procedure and the cam be in good condition ?. I have checked my oil and have yet to find metal shavings. The cam is a flat tappet, with 282/292 advertises duration. it seems to be running real well but any suggestions on a correct break in would be very helpful. The motor has been sitting for most of the time.
Thanks
Old 02-04-2008, 08:21 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
No it's not too late. When you get ready to start it the next time this is what I would do. Adjust the idle speed to 3000 rpm and keep it there until the thermostat opens, or the engine is at operating temperature. This is usually between 3-5 minutes. Lower the idle speed to idle and let it idle for the remainder of a total 30 minutes. Turn it off and let it cool down, check all fluid levels. You should be good to go. NOTE: during that idle time, make all of your timing, carb adjustments.
Old 02-04-2008, 08:27 PM
VROOOM !!!!!!
Ok thanks
I have heard of 2000 rpms for that but i guess 3000 wont hurt it. What would be the difference if u set one for 2000rpms and one for 3000rpms but i will follow your advise thanks
Old 02-04-2008, 08:54 PM
My 2 cents worth
Wiki Edits: 3
If you set it at 2000 it wil take it longer to reach temperature. Most likely 10 minutes or more. I ussualy leave performance motors at 3000 for 30 minutes when I first fire one off. Right after I have done that, race crews have taken their cars straight to the track for hot laping, then qualifing, and raced, all within the first 6-8 hours of the first engfine start-up.
Ain't had one blow up yet!
Old 02-04-2008, 08:58 PM
VROOOM !!!!!!
Thanks Ill try that
Alright ill try that tommorow but i go to switch my flywheel first
Old 02-04-2008, 10:16 PM
Last journal entry: Journal Update
Cam Break In
Another suggestion that comes from my engine builder is to use ROTELLA T 10W-30 during the breakin. Or an additive. Oil companies are lowering the zinc level and can cause excessive wear. He told me that he's seen more cam damage recently than ever due to this. (Just had my 454BBC rebuilt by him) and said that even Crane Cams has a break in procedure or an additive. Here is a link to the exact sheet that came in with my cam. http://www.cranecams.com/pdf/548e.pdf
And here is a link to similar discussion right here on Hotrodders:
continue with diesel engine oil?
Old 02-08-2008, 02:22 PM
Hope it works out ok for you with the above procedure. I've seen guys wipe the lobes off a cam in an hour or so by not using assembly lube. Hopefully, you got off lucky.
late model engines chevelle_502 Engine 3 12-04-2010 11:51 AM
700R4 Late shifts yesgo Transmission - Rearend 12 05-06-2007 03:27 PM
SRTA (700R4) shifts late % Too hard PLWC Transmission - Rearend 1 02-15-2007 05:20 PM
Late model junk...it can be fun!!?? Sandflea427SS Hotrodders' Lounge 10 01-10-2004 07:20 AM
late 2-3 shift in th350 with transpak joeyg329 Transmission - Rearend 2 07-19-2003 03:32 PM
