late 60's dodge pickup d60 rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2002, 09:13 AM
Post late 60's dodge pickup d60 rear
would this be a good canadate to put in the rear of my 48 plymouth? I plan on running 600hp and posibly more as time passes. its 29 spline and drum brakes. any input would be great.
thanks
Old 03-14-2002, 02:45 PM
Post
Avoid the older low spline 60's. The good stuff has 30 or 35 splines.
Old 03-15-2002, 05:36 AM
Post
he said its a 29 spline so I hope that will be ok (and it will probably need to be shorted so i can get it re-splined then and I want a detroit anyways so the carier will need to be replaced too)... I'll probably convert it to disk drakes any one done this? Thanks for the info
[ March 15, 2002: Message edited by: popazeus ]
[ March 15, 2002: Message edited by: popazeus ]</p>
Old 03-16-2002, 07:47 PM
Post
I've actually never heard of a 29 spline Dana 60. There was a 19 spline 60 around that time. I would avoid it personally...
Detroit is sweet. I find lockers to be quite streetable and 100 percent reliable. Detroit is hella-strong too. Good choice.
But I would hold out for at least a 30 spline unit.
