Late 70's Chevy 350 temperature - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2008, 05:27 PM
Can someone tell me the optimal operating temp for a late 70's Chevy 350? I just installed a pair of electric fans and had to move my temp sender by the outlet to the radiator and it is running at a consistent 205 degrees....at what temp should I be concerned it's running too hot?
Old 03-13-2008, 05:44 PM
Jmark's Avatar
I would not be concerned until it STAYED at 230-240. You may be able to adjust the fans too. Some controllers can be set to cycle at different temps.
Mark
Old 03-13-2008, 10:53 PM
It was running on average at 195 with a mechanical fan in a shroud with a pusher fan that was manually turned on when the a/c was on. I switched over to 2 off set 11' in fans as pullers and lost the pusher in front. I figured it would run cooler, but it isn't. I fabricated a mounting plate to hold the fans that I cut panels out of to allow for flow through on the sides of the fans. I'm thinking I will recut them and leave them solid and pull the fans off to about a 1/2" and seal all around the plate to create suction over more area of the radiator...any feedback?
Old 03-14-2008, 08:35 PM
My 350 runs a steady 205 degrees or so. I'm not worried about it.
finally finished chevy 350 build redneckrodder Engine 7 05-30-2011 06:03 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
350 chevy help joesnova2 Engine 7 11-08-2009 05:46 AM
buick 350 - chevy 350 72buick Engine 23 10-13-2009 08:38 PM
