Late model 4.6 in a 70 Maverick ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2002, 01:40 PM
Mav's Avatar
Mav Mav is offline
Post Late model 4.6 in a 70 Maverick ?
Does anyone know where i can find an aftermarket wiring harness so i can install a late model 4.6 in a maverick ?
Ive got a turbo 4.6 out of a lincon i want to drop in my maverick but im not sure how to wire it up with the mass of wires piled on top of the motor lol
[ September 25, 2002: Message edited by: Mav ]</p>
Old 09-25-2002, 11:03 PM
mustang66maniac's Avatar
Ford Freak
Post
I would check with Painless Wiring. You'd be suprised to see what they have.
A 4.6 in a Maverick?? Are you sure thats going to fit? I've never seen under the hood of a maverick, but i do know its a spawn off the mustang. Keep in mind that a 4.6 SOHC is about the same width as a 460. WIth a turbo, im thinking it'll be pretty crowded in there.
Old 09-26-2002, 06:00 AM
Biggarmike's Avatar
Chief Procrastinator
Post
That 4.6 is a sweet motor, as far as itty bitty OHC motors go. There is a guy here in town who put one in a 64 T-Bird. He used some original (donor car) wiring and the rest from an aftermarket company. I think it was Painless. It will be tight but it should be a great driver.
Old 09-26-2002, 07:28 AM
aka Duke of URL
Thumbs up
There are two ways to get the 4.6 to sit in the MAVERICK chassis. Either remove the spring towers and go to MUST II suspension (gives you rack & pinion) or install notching kits on the towers to give you the room. There are suspension upgrade kits available to give you improved steering/handling with the old system also.
What model LINCOLN is the engine out of? A TOWNCAR uses the 2V and the MARK 4V.
I can tell you from experience the 4 valve walks and would be something in a light chassis.
Old 09-26-2002, 07:35 AM
aka Duke of URL
Red face
FORGOT
I would first speak with FORD RACING TECH on this conversion as I am sure they have or are working on a wiring harness by now for retro-fits. Next, speak with the folks at WINDSOR-FOX PERFORMANCE as they have done this swap into an early MUSTANG chassis.
FORD RACING TECH (810) 468-1356
When you open the hood on Saturday night and they ask what you have, tell them a 427 SOHC and see how long it takes them to figure it out...
Old 09-26-2002, 09:02 AM
Biggarmike's Avatar
Post
Yeah Kutulz, a cammer in a Fairlane or stang would be sweet! The FE 'Bolts were impressive, imagine one of those pups w/ the SOHC!
Old 09-26-2002, 03:16 PM
Mav's Avatar
Mav Mav is offline
Post
Thanks for the leads guys... Ive already talked to Painless and they said they could hook me up...
As far as the fit i think im going to use the mustang II front end and just shave the shock towers smooth. It'll be a snug fit but no worse than a stang ... The 4.6 came out of a mark VIII (LSC I believe)
thanks again for the leads ...
[ September 26, 2002: Message edited by: Mav ]</p>
Old 09-27-2002, 11:24 AM
Joe S's Avatar
Post
Speak with Ford they have been great to talk to and they have saved me money on my 5.0 swap over painless.
