Late model alternator - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2007, 10:23 AM
Last journal entry: car is painted
I am planning on installing a new alternator on my Chevelle. I want a high amp alt that doesn't have heavy rotating weight. I am installing an electric water pump so I will be making brackets anyway. I would prefer a late model GM one, that hopefully my pulley off my 70's style alternator will work. Does anyone know of something.
Thanks
Old 03-06-2007, 02:47 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
You might take a look at a GM , CS Series Alternator, High Current, 130 to 140 Amp output, about the size of an SI series, easy to wire (about like a 3 wire SI series) , and should do what you want.
These can be found on most late model GM cars..
Powermaster ALSO makes a line of different size , shape , weight Alternators for racing applications..
Be prepared for sticker shock..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 03-06-2007, 04:35 PM
One word of caution about the CS130 series. These are frequently found on FWD V6 applications. In many applications the alternator is mounted (and thus grounded) through the front frame only, but all the electronics are in the rear frame. The aluminum housing corrodes against the iron stator core, which breaks the ground path and causes the voltage regulator to die. I ended up replacing one annually for three years (fortunately the original replacement was a lifetime warranty) until I found the service bulletin that talked about this problem. The easy solution is to run a ground strap or wire from the rear frame to the block. Problem solved.
Old 03-06-2007, 05:22 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Good Point!
Always run a Ground wire from the Ground buss to the Alternator ground lug..(All alternators!)
Mounts being Chrome, or powder coated, or WELL painted just don't give as good a ground as needed sometimes..and that can change over time as well,
The solution : a 10 gauge ground wire to the ground CABLE At or near the starter..use STAR and Lock Washers, and BURNISH all paint and grease/Oil or dirt from the area, be sure the connection is tight.
Doc
Innovations
Old 03-06-2007, 05:25 PM
alternator
I put an alternator from a 82 firbird rated at 100 amps on my 66 chevelle. check with Mad for their wiring kit. Cost of install was less than 150 bucks.
Old 03-06-2007, 05:28 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Curiosity..
What Alternator did you use..?
Doc
Innovations
Old 03-06-2007, 05:40 PM
doc
sorry Doc, i do not know what type. It was a stock Delco off a 1982 Firebird that was rated at 100 amps. Oreillys had them because i had to replace it some years ago. Al
Old 03-06-2007, 05:55 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
It was probably an SI series.. (two wire plug and one output lug (bolt) and ground lug..
If so, I didn't realize those harness's were THAT expensive!! I thought more like $15.00...
Assuming your stock system was a Generator/Regulator system ..or Alternator/regulator (external types)..
This won't make you feel any better, but you CAN build that harness for like less than $10 bucks if you have the plug..with some 14 gauge wire (brown and Red in color about 6 feet long.. ) and a solder Iron, and some shrink tubing..and about an hour of your time..
Here is how:
The CS Series differs from that a bit..but just as easy to make..If you have the plug..
Maybe tuck it away for next time...save some bucks..
Doc
Innovations
Old 03-06-2007, 06:03 PM
alternator
Doc when i did this the kit was 25 bucks back then. Your info is great, ill put in my save pile. Al
Old 03-06-2007, 06:09 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Whew!
Glad to hear you didn't spend that much on it..
I'm thinking it's me for me to switch product lines..
Doc
Innovations
Old 03-08-2007, 05:54 PM
On my '75 pickup I switched from a 63 amp 10si to a 94 amp 12si without any difficulty. Pulley size was the same and I used an OEM belt and mounting brackets. Just make sure the clocking is the same.
I also upgraded the charge wire to an 8 gauge wire, and ran it directly from the alternator to the battery, using a 12 gauge fusible link at the battery connection. I can turn on lights, heater and everything else in the truck and still show about 13.8-14 volts.
Bruc
late model efi on a 1st gen. 454ci mark53 Engine 3 01-08-2007 12:38 AM
alternator wire hanging in mid air?! pcoghlan Electrical 11 03-21-2006 02:47 PM
alternator problems woodmanscott@hotmail Electrical 7 01-18-2006 05:06 AM
Late model Explorer rear for 46 GMC Kermitt47 Transmission - Rearend 2 12-31-2004 01:55 PM
late model bed on classic truck Lightspeed Body - Exterior 6 09-25-2002 11:32 PM
