late model engie swap nightmare
I have installed a late model 350sbc and a700r4 in a 1966 Impala station wagon. The engine has vortec heads,a GM performance throttle body intake,headers I believe it is otherwise stock. I put a frame mounted electric fuel pump for a 85/86 ford p/u I have tried to start the car with no luck. I can get it to barely run/idle only if I pinch the return line off. The manual I have for my 92 roadmaster wagon says with the key on but engine not running it should show between 9 and 13 pounds of fuel pressure. I put a Holly fuel pressure gauge inline turned the key to the on position and it only shows about 2lbs about 5/6lbs if I pinch the return line. Cranking the car it shows about 20LBS, but when I stop cranking but leave the key in the on position the gauge drops back to 2lbs in only a few seconds. I hope someone can help me with this while I still have some hair.
