Late Model engine swap
2K views 6 replies 6 participants last post by  nannie
Let's say a guy buys himself a 98 Camaro with 3.8 six cylinder and 5 speed manual. Will a 350 V-8 bolt up to the six cylinders bell housing or would you have to change everything out.
Thanks
#3 ·
Engine swap again
John I realize they are 2 completely different engines, but take for instance a 67 chevy nova with a straight six. You could pull it out and bolt a 327 straight to the bell housing and you were good to go. Just didn't know if they kept making everything compatable on these late model cars.
Thanks
#4 ·
Thanks
Things have changed alot since 1967! :D
#6 · (Edited)
the late model 3.8 is a 90 degree v-6.. but has the 2.8 bellhousing bolt pattern. it will not interchange. but, there is a possibility that the bellhousing from a v-8 would work on the transmission... and then yes, it would then work. might want to check w/crosley about this more in the transmission section... he may also know if for sure it'll work, and also if the v-6 trans will hold up to the power of the v-8...
