Later than Mustang II IFS
I need a little help from you IFS guys. I ahve a 47 Plymouth tudor needing an update of front end parts. I am considering a variety of choices such as a Mustang II kit from Fatman (expensive but the engineering is done), a Volare/Aspen K-frame that requires major frame surgery, and now I'm considering a later Mustang IFS from an 88-93 car with the strut front suspension. But I have some questions and I hoped someone might be knowlwdgable. I can get the whole front end including frame section, from a number of post II Mustangs from 83-93. However, they are all 4-bolt, small brake cars and therefore questionable for a big sedan with a "small" Desoto hemi. Are there alternatives on these cars to install bigger brakes and heavier struts without going to a whole 5.0 front end assy? 5.0 front stubs that haven't hit something very hard or aren't very expensive, are hard to find. Will the aftermarket rotors with 5-bolt X 4 1/2 pattern rotors fit the later spindles? Are heavier struts a bolt-in or do they require 5.0 a-arms and ball joints? I know the bigger rotors use the same calipers, but require the 5.0 caliper brackets to space it out. But my Ford salvage guy thinks all the other pieces are bigger and heavier too, but he's not positive. What do you think?
Thanks for any inputs you might have. Barry
For the most part, the 79 to 93 FOX MUSTANG is the same suspension. Lower control arms are basically the same and later rotors can be exchanged to give you larger brakes. The LINC MARK VII (also on FOX platform) will give you five stud larger rotors and larger caliper pistons. Now this is a McPherson Strut assembly and you would have to somehow fabricate upper strut mounts for the conversion.
There was once a kit offered to allow the use of an upper control arm. That would make the conversion easier. Search FOX MUSTANG and you will get a plethora of information on upgrades. |
Foxy plymouth
Thanks for the input. I'll check out that site. I looked at some Mustang stuff but didn't hit the right spot. My buddy is building a 56 Studebaker station wagon and is using an 87 strut front end off a Mustang. It makes a neat installation, but he has the 9-inch brake rotors redrilled for a 5-bolt, 4 1/2-inch pattern. He retained the struts but I'm concerned about structural strength since he only kept the strut towers and tied it into the Stude sheetmetal. If I use the Fox front end, I'd keep the struts but probably retain the surrounding sheet metal and tie it in to the Plymouth inner panels. Appreciate the info. Thanks
I bought a "kit" from Jim Myers racing for my '60 Corvette, Mustang R&P steering, coil over shocks and disc brakes. The disc brakes are from an F body (Camaro/Firebird). You might call them or look at their site and see what they have that would work for your set up. Good Luck.....
http://www.jimmeyerracing.com/ |
Thanks Firstgear
Hadn't looked at Jim Myers. Have looked at Morrison, Chassis Entgineering, Fatman and some other magazine ads. Mopar rods other than 33-34 not on anybodies radar. Thew Plymouth chassis is a late model style IFS with an upswept front frame so it isn't a simple MII candidate like the old Fords and Chevys. Also will look at or talk to TCI and some others. Thanks
Later than MII
Thanks tbirdscott. I'll have to check the local Ford yard to see what's available. They have a lot of 4-cyl Stangs but only one GT that is broke on the left front. GTs and TCs are getting costly even as salvage and the yard said their boss won't even bid on them anymore. I thought the Fairmont, etc, might fit. Cougars are fairly rare. Do you what years might fit? Or are the 80-88s the only years? Really appreciate the input. I can use the 4-cyl Stang front frame clip and will replace the other goodies with new/rebuilt stuff, but needed to know if bigger parts would fit and what to search for at the parts stores.
Later than MII
Hey guys! I just thought I'd provide an update to my saga of a 40's Mopar IFS search. From results on this forum and some from the 5.0 Mustang forum I have some useful info I want to share. The post-MII front suspension is a strut type front IFS with front mounted R&P steering. From roughly 83-93 you get the Fox front end which has 4-bolt front brakes with 9-inch rotors. For a fat-fendered rod this is probably inadequate. My car has a 57inch front track. The Fox is about 58-inches, a good fit. TYo get the big ii-inch brakes, you'd need the rotors, calipers, brackets, and spindles, including some hardware, from a 94 or 95 Mustang. All post 93 cars are called SN-95 chassied cars. 94and 95 maintained the same track width, or only a slight increase. 96 and later Mustangs went to about a 63-65-inch track, which is too wide for me but might work on a bigger car. Buy using the 94/95 brakes on the Fox front chassis, you get a strut front IFS with 11-inch, 5-bolt brakes. You'd keep the Fox lower control arms and struts/shocks. The big drawback to this front end is the struts which tie into sheet metal. The Mustangs are unibody cars. These strut tower sheet metal would have to be tied back into the body at the firewall for stability or you'd need to make hoop braces from the firewall to the framerails tied to the strut towers. A Mustang owner in my Mopar club says that these cars need either the hoop or a triangular export bar to tie the strut towers to body or there is excessive flexing of the sheet metal around the satruts during hard maneuvers. I'm still waiting til my other friend gets his Studebaker wagon on the road to see how it works. I may have found a company that makes an MII kit for my 47 that is cheaper than Fatman's. Thanks to everyone who contributed. You guys are the best. Barry
Later than MII
Segge: I read about the Cobra,etc, stuff. However, the spindles needed add width to the track. Anything over 60-inches is too wide for me and the Bullitt stuff has a 63-inchtrack. Even if used on a Fox chassis, its wider than the 94/95 stuff. The 5.0 Forum has a comprehensive article about the brake upgrade. The 13-inch brakes require 16-inch or bigger wheels and I'm not looking to go with that look on my rod. But thanks for the heads up. If I was going pro-street or weekend warrior,the 13-inch stuff woulkd get a hard look.
| Mustang II IFS Install in 57 Chevy Truck | mestes | Suspension - Brakes - Steering | 7 | 01-24-2012 08:12 AM |
| How to properly mate a GM pump to a Mustang II rack | Centerline | Suspension - Brakes - Steering | 73 | 10-31-2009 11:59 AM |
| Mustang II IFS Steering Adjustment | horvath | Suspension - Brakes - Steering | 14 | 05-08-2004 11:25 PM |
| mustang II ifs specs | Blob | Suspension - Brakes - Steering | 1 | 12-24-2003 09:48 AM |
| Are Mustang II Crossmembers Safe? | Jon | Suspension - Brakes - Steering | 14 | 10-17-2003 12:43 PM |
