Lateral alignment of rocker tips - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2008, 02:56 PM
v8hed's Avatar
AK427
How critical is it to laterally align a roller rocker tip on the valve stem? Mine are slightly offset. Should I attempt to adjust the guide plates?
Old 07-28-2008, 04:24 PM
For a mild street engine it's not too critical. If it's running really stiff springs and lots cam lift and turns high RPMs it gets more critical.
Bogie
Old 07-28-2008, 04:25 PM
v8hed's Avatar
AK427
Bogie
Ok, thanks. It's a street rod with a Comp XE274 hyd flat tappet and won't see more than 6k.
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
roller rocker tips off center from side to side awoodman Engine 8 11-17-2007 08:25 AM
Rocker arm alignment on Dart Heads TurboS10 Engine 18 05-16-2007 09:50 PM
Outer Rocker Work modas Body - Exterior 3 11-01-2006 06:07 PM
Roller rocker alignment Chevy BB LeadfootBob Engine 1 06-04-2006 04:17 PM
