lateral gas ports - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-23-2012, 08:59 AM
With the right weigh oil, you think they will seal with no problems?
  #17 (permalink)
Old 12-23-2012, 05:10 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by birkey View Post
I know all that but do the holes go under the piston? If so how do they get any pressure to push them? I'm curious how lateral ports will help seal if they are not connected to the combustion chamber. Are they?
I think where you're getting confused is the top of the piston- above the top ring- is a smaller diameter than the ring lands. Because of this, the area above the top ring is exposed to combustion chamber pressure.
This isn't something that's even needed on 99% of the engines used on the street. Even a regular tension set of 1/16" rings don't gas porting. And 1/16" rings would be something worth looking at if you plan on twisting the engine to 7K rpm.
Lateral alignment of rocker tips v8hed Engine 2 07-28-2008 04:25 PM
Q-jet ports JG700 Engine 3 07-20-2007 09:32 PM
Lateral G holding ability slavboy1 Suspension - Brakes - Steering 2 10-03-2004 12:20 PM
Big Block piston gas ports, expert help needed deuce_454 Engine 3 12-14-2002 03:28 PM
vacuum ports 46_stvblt Engine 2 11-26-2002 04:12 PM
