Bob, if you raise the engine an inch or two, you probably won't have to do anything to the driveline due to the driveshaft angle. You will want to raise the tranny mount just enough to line the driveshaft up. In other words, you want a straight line from the front main engine bearing, through the tranny shaft, through the drive shaft all the way to the rear axle. If you have any other questions, you can e-mail me and I will try to help. I am no expert but I might be able to help.
