Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lathe Identification and general info?
Old 04-28-2009, 05:51 PM
JoshF JoshF is offline
I was given this lathe on Sunday. I have always wanted to learn how to use one, so hopefully this is the good deal I had been waiting for. I am cleaning it up, but so far I have not found anything written or stamped onto the actual machine. The motor, which judging by the bracket is not original, appears to be a "Master" with a wheel shifted transmission.
I am a complete beginner with lathes and machine work in general so any input is appreciated. I have mounted the motor after taking the pictures and everything turns but the auto/manual feed selector had a broken piece I have taken apart to weld up, at which point I think everything will be moving as it is supposed to.
Does anyone have any idea what make/ model/ vintage machine I might be working with?
Is there anything I need to know?
What tooling should I buy first (I did not get any with it)? I am not looking to make anything in particular first, I will probably be turning whatever I can to learn how to run it.
Thanks,
Josh
Name:	Photos 4.23.09 003a.JPG
ID:	37882   Click image for larger version
Name:	Photos 4.23.09 004a.JPG
ID:	37883   Click image for larger version
Name:	Photos 4.23.09 005a.JPG
ID:	37884   Click image for larger version
Name:	Photos 4.23.09 006a.JPG
ID:	37885   Click image for larger version
Name:	Photos 4.23.09 008a.JPG
