launching my pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2006, 09:38 AM
traction
i've got a 1963 chevy fleetside pickup and all i do is spin the tires. just wondering if there was anything i could do to get some traction, the truck is pretty much stock.
Old 01-11-2006, 10:54 PM
1) better tires
2) better suspension
3) weight in the bed
4) ...... .......don't mash the gas so hard......
Old 01-12-2006, 06:50 PM
what do you mean better suspension. all it has is trailing arms, coil springs and shocks. theres not much i can do. that i know of
Old 01-13-2006, 08:13 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
You said tireS.... so I conclude you already have a posi-traction of some kind.
Super sticky tires....
Shorter and stiffer springs and/or stiffer shocks so the rear won't squat when launching. Maybe airbags inside the coils springs.
Other than that, balast in the rear and better weight transfer to the rear.
Old 01-13-2006, 08:33 PM
The front suspension is as important as the rear suspension. The better it transfers weight to the rear, the better your traction will be.
The first rule of traction is 'Traction Begets Traction'. If you don't have the tires to start the weight transfer process, you'll never get the traction you need.
Go to www.google.com and search for words like drag racing suspension or weitght transfer.
Old 02-08-2006, 07:59 PM
launching my pickup
I've got a 1963 chevy shortbed pickup with a fairly close to stock 350 and a 700r4 in it. I think it has 3:73's in it. My problem is that i want to get more weight transfer to get the truck to hook up. it has coil springs in the front and back but the suspension is all stock. any help would be great.
Old 02-08-2006, 09:31 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
with that 4 coils suspension you will be hard pressed to get a better weight transfer then those HUGH FACTORY ladder bars
sounds to me a Posi chunk & some wider stickier sneakers for the back
New springs might help it too
IMHO
R
"SlowRide66"
"Illegitimis non carborundum"
Old 02-08-2006, 09:45 PM
I merged the two posts together..........this has been hashed out already....
pickup tube wont fit in pump Johnn Engine 11 04-25-2005 11:12 PM
32-34 pickup grills mehegan Introduce Yourself 1 12-19-2004 12:17 AM
LT1 in a pickup SAATR Engine 2 01-09-2004 12:24 AM
40 Ford Pickup Body Parts enemyace Body - Exterior 1 03-23-2003 10:54 PM
1932 Ford Pickup and 1933-34 Pickup Different? YES pasadenahotrod Transmission - Rearend 1 10-23-2002 02:20 PM
