Launching with a TH350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2009, 06:50 PM
DENCOUCH's Avatar
I am a little on the noob side when it comes to launching an automatic from a standstill, how is it done correctly? The way I see it, I can wait for the green, and then floor it. I could also stand on the brake and bring up the revs. If I have a 3200 stall, how should I build up to the grand event?
Appreciate it guys.
Old 02-23-2009, 07:46 PM
life is a temporary assignment
Appreciate it guys.
You should be able to hold the car back,Hold the brake in rev it up to about 2800 to 3000,When you see the last yellow lite,Lite up, Put It on the floor.Leave when you see the last yellow lite,Lite up.It take's a little timing,But you will get it. Never wait for the green,Then you will be sleeping.
Are put a trans brake in your transmission,Then just hold the button,Rev it up,And let go of the button,And hold on!!!!!!
T-350 Rebuild Tech jakeshoe Transmission - Rearend 10 10-05-2008 03:58 PM
Getting correct filter for TH350 75gmck25 Transmission - Rearend 2 06-21-2008 12:04 PM
Transmission swap: TH250 to TH350 Torque converter issues. 35oldstruck Transmission - Rearend 5 05-21-2008 03:43 PM
Stock TH350 capacity 307malibu Transmission - Rearend 7 11-01-2007 10:16 AM
th350 in 67 Tempest csob Transmission - Rearend 1 02-19-2006 09:45 AM
