laying fiberglass - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2005, 02:42 PM
laying fiberglass
I have a 41 dodge streetrod and would like to make a molded in rear end with a lights and a license plate holder? i was going to make the mold out of Styrofoam then cover it with fiberglass. but i was told that the resin would melt the Styrofoam.any suggestions on putting something on the foam first before laying on the matting? if so what kind of matting should i use?i am not experienced at this at all?Thanks
Old 07-15-2005, 02:53 PM
MAS Line Design
if you have a plastics supply house nearby go on over and ask them for a block of the stuff they use to make surfboards out of.
you can sand it and shape it to make your plug
Old 07-15-2005, 03:40 PM
bet on black's Avatar
hotrodder 4 life
foil or plastic wrap works too.
Old 07-15-2005, 06:40 PM
mrcleanr6's Avatar
yes, its a special foam. ridgid urethane to be exact. comes in different density. i order the stuff from general plastics. called last-a-foam in 4lbs per sf. they have a website.
Old 07-15-2005, 09:47 PM
302 Z28's Avatar
You can use Styrofoam it's a lot cheaper than polyurethane. You must cover the Styrofoam with plastic packaging tape though before applying the fiberglass resin. The tape will protect the foam from the resin and the resin will not stick to the packaging tape.
Vince
Old 07-15-2005, 11:25 PM
Last journal entry: metal finish
Use epoxy resin it doesnt melt the styrofoam.. go to home depot or lowes and get the blue foam its cheap.
Old 07-15-2005, 11:32 PM
mrcleanr6's Avatar
yes vince you are correct this will work if your not making a piece where you need any detail of the part. the idea of the urethane foam is when your done shaping the part you can prime it, sand it smooth and wax it so when your done you can make a mold or pull a part from it that is exaxtly the same. the other way you will need to do bodywork to the actual part since it will have a packing tape like finish.
Old 07-17-2005, 08:39 PM
Bad Rat's Avatar
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
Use the ridgid blue or pink foam .. shape the piece the way you want it then cover it with a layer of bondo and sand it smooth,, then you can use that for a plug to make your part, its a bit of work ,, but sanding bondo is much easier than resin, be sure to use a mold release wax or pva water base mold release,, the wax works better, I think GOOD LUCK Bill
Old 07-17-2005, 08:44 PM
the bondo will eat the foam a little.. its best to put a layer of matt using epoxy resin then when that drys do ur filler work.
Old 07-17-2005, 09:17 PM
Riot Racing's Avatar
Last journal entry: Por 15
I own a BMW performance shop and we do LOTs of composite work. In my experiance sytrofoam will nto work for ANYTHING. FOAM will, there is a huge difference.
urethane is way better and way more expensive.
Any of these materials are hard to cut and hard to work into shape, FOAM guys are true specialist. Depending on the complexity of the task at hand you are looking at a much biggier task then you imagine.
BUT... using fiberglass to cover it all will help cover the flaws, then using bondo. BUT, use kevlar instead cause it is cheaper. If u need a material source let me know, dont pay more then $3.00 a linear yard for kevlar.
Also, trying to get your "foam" shape to stick to the body is goign to be a challenge, then making it all look "natural" is going to be the biggest challenge of this project.
Good luck and let us know how it comes out
Old 07-17-2005, 09:38 PM
Wow, thats a good price.. what website is it?
Old 07-18-2005, 12:08 AM
hers some helpful sites
http://www.fiberlay.com/
uscomposites.com
Ill tlak to our ordering department tomorrow and ask who we buy direct from. They may not sell small quantity or to someone without a wholesale licence. Send me an email to remind me
pokerface@adelphia.net
Yet another question about bonding fiberglass to metal Psionic Body - Exterior 41 10-20-2013 07:56 PM
How Do You Make Things With Fiberglass? Silentlion_69 Body - Exterior 11 01-01-2006 09:05 AM
fiberglass to fiberglass scoop bluebu Body - Exterior 62 06-23-2005 06:15 PM
Fiberglass fenders jcclark Body - Exterior 4 06-16-2005 07:25 PM
Fiberglass help for novice tyman00 Body - Exterior 1 10-20-2004 01:36 AM
