Lazer Dry
All this talk about the failure on my car has stirred quite
a debate, here and elseware. I don't intend to "bad-mouth" Kirker, they make some good products. I probably did something wrong, just don't want to repeat it. Points for clarification: 1. I used a different enamel brand. That was probably my mistake in itself but I got it all at the same store and that's what they gave me to use & recommended. "I should never assume" (I'll write it 100 times). 2. The lazer dry says "Kirker recommends the use of a hardener" I interpeted that to mean "optional" - IT"S NOT!. The paint rep for Kirker says it's mandatory-my mistake. I may not have used hardener, I can't remember. 3. I used a differt brand clear-I don't think that matters. 4. Everything painted was well sanded (factory finish) and covered with 2K primer, allowed to dry 1 week, sanded then painted. 5. The directions were followed exactly for mixing, except maybe the hardener part. 6. Most important- It was "perfect" for over 3 years, never waxed, and is only failing where the sun hits it. AND the clear is fine over it. When I sand through the clear then the color- the color under the surfaced dark spots looks normal along with the 2k primer underneath. If it weren't clear coated the spots could be buffed off. I am repainting with the same stuff in order to sell it, I'll be sure to use hardener. I probably will never know if it helped. Thanks to everyone who contributed, I really appreciate it.
| Maaco vs. At-Home Paint Job | nightrain_rod | Body - Exterior | 127 | 08-26-2012 03:07 AM |
| SG 100 HOK intercoat clear, any tips for dry pearl? | wreckedGTI | Body - Exterior | 10 | 08-01-2005 07:04 PM |
| Block Sanding. Dry or Wet? | 67LS1T56 | Body - Exterior | 11 | 07-31-2005 08:55 PM |
| wet vs dry carb flow ratings | Litdave | Engine | 10 | 09-08-2004 06:15 AM |
| dry spots | malibu350 | Body - Exterior | 1 | 06-27-2004 08:34 PM |
