LB.9 305 tpi ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2007, 12:47 PM
LB.9 305 tpi ?
I bought a 86 model LB.9 305 tpi. i am going to pull my 327 and change heads and pistons, i was wondering if i put my holly street dominator dual plane intake, 600 edelbrock, 1 5/8 long tube headers, plan on putting a new hvhp oil pump, new gaskets and seals, deleat all smog and a.c. stuff, plus adding a edelebrock perfomer cam and lifters, the little motor had 190 hp. what can i expect as far as torque should be pretty snappy till i put the 327 back. car is a 73 nova 3200 lbs. 350 turbo, shift kit, 373 rear gears your thoughts are always welcome. thanks Wormy.
Old 01-26-2007, 03:31 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Hard to follow exactly what you're doing, but skip the HP part of the oil pump. Just do HV.
SBC 283 and 305 With TUNED PORT INJECTION TPI boneyard Buick Engine 14 07-11-2005 02:49 PM
305 TPI swap to a '76 350, can it be done? 70bird Engine 12 12-22-2004 01:39 AM
Tpi 305 To 350 Teejay68 Engine 3 11-26-2004 01:43 PM
Selling price for 305 Tpi? Chevy Thunder2 Engine 3 03-24-2004 05:25 PM
Carb'd 305 to TPI 305, help? coolerow Engine 2 09-23-2003 04:10 PM
