LCA wont fit in frame slot?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2013, 05:52 PM
What can i do to fix this problem?? I got new bushings pressed in so maybe they.tweaked the arms a bit during the press..i dont want to hammer the slots nd then find out my springs wont fit correctly..this is a frame off..thx for the advice
Old 10-12-2013, 07:39 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
How about some background information... what are you working on?
Old 10-12-2013, 08:29 PM
Im working on a 76 monte carlo..i disassembled it...got frame powdercoated as well as control arms..installed polyurethane bushings and all of a sudden the same arms dont want to budge in
Old 10-13-2013, 06:26 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Probably a combination of the powder coating and new bushings.
Had a similar issue with my 66 Elky and all it got was new rubber bushings.
A block of wood or a big plastic/rubber dead blow hammer should knock that
thing right into place.
The inner shaft of that bushing is supposed to be a tight fit.
Once that bushing bolt is tightened up (after the car is on the ground or simulated)
it does not move at all---with rubber bushings.
I believe the poly bushings slip on the tube and the shell----not sure, I always use the rubber ones.
Also had the same issue when putting a NEW LCA in my Crown Vic---did not want to go in at all.
Some bending the ears of the mounts a bit got it to slip in and when tightened up
all was well.
radiator wont fit fernridgegeneo Engine 1 03-07-2012 09:14 PM
327-383 now starter wont fit sooper Engine 5 02-28-2010 04:51 AM
pickup tube wont fit in pump Johnn Engine 11 04-25-2005 11:12 PM
Why wont my headers fit?????? "70" Cougar Engine 8 09-12-2004 06:32 AM
Harmonic Balancer wont fit s10V8-357 Engine 16 10-08-2003 06:02 AM
