Lead repairs - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2008, 11:30 PM
1949HevyChevy's Avatar
Last journal entry: 1949 Chevrolet
Lead repairs
I am getting ready to put some direct to metal primer, when I was sanding the body I found some areas to have lead. It appears that it came from the factory like that. My question is should I remove it and use body filler, or should I just leave it.
Thanks
Old 10-21-2008, 12:22 AM
BMM BMM is offline
Leave it. If that area needs some filler, or you want to fill the seams, than put filler on it. But there is no point in removing it for no reason.
Old 10-21-2008, 07:27 AM
302 Z28's Avatar
I agree, the lead is a far better repair than polyester filler, and you would be exposing yourself to a health hazard if you try and remove it.
Vince
Old 10-21-2008, 09:26 AM
35WINDOW's Avatar
Last journal entry: Engine!
Make certain that the Metal under the Lead is sound-I found that I had some rusting Metal under Lead and had to replace it-
Old 10-21-2008, 05:27 PM
Lead repairs
Thanks, there were two areas were the lead was like a bubble and I ended removing the lead and found that it was rusted bad, had to cut the piece out.
but there is other areas that look OK, from both sides of the panel, I will leave those areas alone.
Thank for your help
Epoxy primer over lead? Slickriffs Body - Exterior 2 09-13-2007 04:31 PM
Bearing question, oil test shows high lead. Jmark Engine 2 06-24-2006 04:29 PM
The death of conventional hotrodding - alternative power Mad Maggot Hotrodders' Lounge 57 01-23-2006 10:51 AM
removing lead filler? dh79 Body - Exterior 16 09-28-2003 10:01 AM
body lead onebadmerc Body - Exterior 20 03-23-2003 06:05 AM
