leaf spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2006, 04:52 PM
leaf spring
Is the stock front leaf spring from 29 model A strong enough to hold up a V8 on a HotRod? if not what year should I get it from and if I go to a local auto parts store, what strength should I look for to support a V8 (350 GM for example)
Thanks!
L.
Old 10-17-2006, 04:58 PM
poncho62's Avatar
Wiki Edits: 5
Probably, but if not, adding a leaf or two is not hard. It should probably be rebuilt after all these years anyways.
Old 10-17-2006, 05:25 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Why not buy a brand new Model A style spring?.....they are available at many places. Posies comes to mind. www.posiesrodandcustoms.com You can also check at Speedway www.speedwaymotors.com
Old 10-17-2006, 05:42 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
If you buy a new one you can get it with Teflon inserts which will give you a better ride. The original springs were super heavy duty to take the punishment of the pot hole filled back roads in the 30's. They will take the weight of your 350. You might even take a spring or two out to soften the ride. But like poncho62 says you should get those old springs rebuilt. The old way to get a better ride was to put grease in between the springs to make them slide better. You can buy Teflon strips to use instead of the grease if you go with the rebuilt old springs.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 10-17-2006, 05:55 PM
Thanks Guys!!!
rear leafs to stiff 2112jb Suspension - Brakes - Steering 12 10-06-2005 07:29 AM
TCI's rear leaf spring installation gavinpierce Suspension - Brakes - Steering 9 06-23-2005 06:00 PM
Who makes a 52" x 1.75" leaf spring? jpd37 Suspension - Brakes - Steering 5 10-14-2004 11:59 AM
8 1/4 to 8 3/4 rear end Leaf Spring Problem... 71gtx Transmission - Rearend 21 04-19-2004 07:17 AM
Leaf Spring Pads, are they really needed? OilPatch197 Suspension - Brakes - Steering 1 04-13-2003 09:42 PM
