leaf spring conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2004, 12:23 PM
jmss96's Avatar
Talking leaf spring conversion
I am converting my 1970 Nova over to multi leaf springs. Used Lakewood traction bars for the bottom, but was wondering if I should have replaced the upper spring perch. I was told I did not have to, but a catalog I have has different part numbers listed for single and multi leaf.
Old 08-16-2004, 09:21 PM
Multi-leaf perches go farther down away from the axle to meet the shock plate. Mono- perches will work if you use spacers made from steel plate. I ran a '69 without spacers, but only for a short time, & I've seen stacks of washers used too, but I'd rather use solid steel. Whatever you do, use 4 U-bolts instead of the T-bolts.
Old 08-16-2004, 09:46 PM
jmss96's Avatar
Spacers where? On top of the leaf spring or to fill the gap between perch and traction bar?
