Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - leaf spring shackles on a front straight axle
Old 02-01-2011, 10:31 AM
hotrod389 hotrod389 is offline
machinist & fabricator
that almost sounds fun!
thanks for the info guys!
yes i will be mounting the steering box behind the axle, with a drag link to the steering arm on the spindle, so my shackles must be foward of the leafspring.
this brings up another question, when a full load is placed on the done front end, in other instances the shackle should be at a 45 degree angle. is this true in this case? and im assuming that its 45 degrees to the rear of the car?
thanks again guys.
