I don't know if there is a difference, I have seen gassers done both ways, but I see nearly all have the shackle up front. The one I'm planning will be shackle up front.
Both the Speedway Motors straight axle kit and the Motion Performance kit both have the shackle up front. So does the Bill Thomas re-creation of their 60's "instant funny car kit" offering, the shackle is up front. |
The big difference would be where the steering box is located.
If you have cross link steering, or a rack, it wouldn't make a single bit of difference where the shackles are. But if you were to mount the shackles at the rear and have a rear mounted steering box with a drag link coming forward to your axle you would have some serious bump steer. The shackle rocking back and forth is bringing the axle back and forth with it. So if you had a drag link between the box mounted on the frame and the axle mounted on the spring that is rocking back and forth your wheels would steer without you turning the steering wheel! Brian |
that almost sounds fun!
thanks for the info guys! yes i will be mounting the steering box behind the axle, with a drag link to the steering arm on the spindle, so my shackles must be foward of the leafspring. this brings up another question, when a full load is placed on the done front end, in other instances the shackle should be at a 45 degree angle. is this true in this case? and im assuming that its 45 degrees to the rear of the car? thanks again guys. |
Brian |
Good suggestions
This is a great thread and alot of help to putting in a "gasser" axle. Thanks
| leaf spring axle floaters | dusty13 | Suspension - Brakes - Steering | 9 | 10-18-2010 11:34 AM |
| Spring Shackles at correct angle? Wrong Axle? | 71gtx | Suspension - Brakes - Steering | 4 | 06-29-2009 03:07 PM |
| straight axle / leaf spring guys, need a simple measurement ... | lowROLLERchevy | Suspension - Brakes - Steering | 3 | 01-20-2006 10:46 AM |
| Question on replacing leaf spring shackles | gator412 | Suspension - Brakes - Steering | 8 | 05-04-2005 10:23 AM |
| single leaf front spring/straight axle | flatheadfreddy | Suspension - Brakes - Steering | 0 | 02-21-2004 01:30 PM |
