leaf spring sliders - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2003, 04:55 AM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Question leaf spring sliders
has anybody tried or no someone using leaf spring sliders,pros or cons? thanks
Old 03-01-2003, 04:41 PM
milner's Avatar
Post
i use sliders in my coupe, i mainly put them in to slow down the wear on the springs and having rust coming out when driving in the rain. they have been in there for about 10 years now.
Old 03-02-2003, 05:56 PM
Post
Zonk,
I think Milner is talkin about the poly liners that go between the leafs to reduce friction.
As far as the sliders you refer to, I don't recall ever seeing any on a street rod, but have seen them used on race cars. If done right they look trick. I don't know how you plan on doing them but I would recomend using some type of bearing for longivity. I've seen some that just has a bolt stuck through the spring eye and that rides in a bracket with a slot cut in it.
Good Luck, Mark
Old 03-03-2003, 07:02 AM
zonk's Avatar
Post
thanks guys,Mark yea, thats what I am thinking about,they replace your shackles,seen them in speedway,heavy duty ones has roller bearings,wondering if anybody has used these,and how they have worked out and lasted,thanks
Old 03-03-2003, 06:48 PM
milner's Avatar
Post
sorry zonk: i misunderstood your question.
