Leaf springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2006, 11:58 AM
Last journal entry: 40 Chevy coupe
Leaf springs
When tightening u-bolts for rear end to leaf springs do you tighten with tires on ground under load or do you tighten off ground without load? Thanks.
Old 11-19-2006, 12:10 PM
I always tighten everything with the tires off the ground ... then after a few miles ... I check everything and re-tighten as necessary ... with the tires on the ground.
Old 11-19-2006, 01:11 PM
Leaf springs
Thanks. Deuce
Rear Leaf Springs ...."Clamping Them?" white66coupe Suspension - Brakes - Steering 12 03-11-2006 01:04 PM
rear leaf springs HD chopped pickup Transmission - Rearend 2 11-05-2005 02:31 PM
rear leafs to stiff 2112jb Suspension - Brakes - Steering 12 10-06-2005 08:29 AM
dearching leaf springs bluechev Suspension - Brakes - Steering 2 08-14-2005 08:16 PM
leaf springs and coil overs jhenry Suspension - Brakes - Steering 2 11-25-2004 06:45 AM
