leaf springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2007, 06:34 PM
leaf springs
I have a 49 chevy pickup with the leaf springs under the axle.
It has 3 inch lower blocks on it. The person that had it before me
cob nob about everything. I'm taking a few leafs out to soften
the ride. I made shorter shackle's to help lower the truck.
My question: the axle is not on center of the leaf springs. The lowering
blocks are behind (towards the rear) of the bolt that goes up
through the leaf springs. The axle is in the middle of my fenders so I don't' want to move the axle. Does this matter or do I need to move the entire
springs back so that there center long ways on the springs
Marcus
Old 01-23-2007, 07:05 PM
You should be fine. I set mine up a similar way. As long as the bolt head is in the divot of the lowering block you should be fine. The rear wheel is usually forward in the opening and offsetting the hole in the block is a way to correct it.
Old 01-23-2007, 08:50 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Not a problem. Be sure to take out the shortest leaves to soften the ride, not long ones. You have to offset the axle center when installing an open drive line. Those trucks came from the factory with torque tubes and the links the factory used to attach it to the spring offset the axle fro spring center. You must do the same thing with a solid mounted replacement open axle to center the wheels in the fenders. Just make sure the new spring mounting pads you weld on the axle housing extend forward so they have a hole that covers the spring center bolt which anchors the axle in place.
Here is the block I made for my '53 which is the same as your truck. Needs to have the height, again to compensate for the tall linkage on the closed drive line axle it is replacing. This tall block got my truck to stock ride height. To get a lowered stance you need to go even taller, play with shackle length, etc.
Old 01-23-2007, 11:09 PM
Links? What the....?
Old 01-25-2007, 07:19 PM
Thanks willy
I was told that if you move the new style axle back 1.5 inches from the center of the leafs it would be center of the your rear fenders??
Old 01-25-2007, 09:05 PM
Wiki Edits: 21
Don't remember the measurement but that sounds about right. The bolt head is off center but still well under my riser blocks so 1 1/2" is probably right on.
Rear Leaf Springs ...."Clamping Them?" white66coupe Suspension - Brakes - Steering 12 03-11-2006 12:04 PM
rear leaf springs HD chopped pickup Transmission - Rearend 2 11-05-2005 01:31 PM
rear leafs to stiff 2112jb Suspension - Brakes - Steering 12 10-06-2005 07:29 AM
dearching leaf springs bluechev Suspension - Brakes - Steering 2 08-14-2005 07:16 PM
leaf springs and coil overs jhenry Suspension - Brakes - Steering 2 11-25-2004 05:45 AM
