Leaf Springs... - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2007, 07:53 AM
www.1965comet.net
Leaf Springs...
Got my new leaf springs for my 65 Comet. When I tried to install them, they were about 3" too short (with shackle) of reaching the rear mounting hole in the frame.
I called ESPO and they convinced me that it was the right springs (22" front to pin, 33" rear to pin)and because of the high arc these springs come with, installation is difficult.
Well with my hydraulic jack, I was able to get them installed but my shackles are pointing the wrong way. I guess I'll need to "force" them over as I compress the spring even more with my jack.
Am I OK or is this just all wrong? Once I do get the shackles pointed the right way, what prevents them from swinging back forward when I raise the rear end off the ground?
Note: The leaf springs hae been relocated inwards for bigger tires but the distance between the leaf springs eyes is the same as the stock locations...
Or will weight on the springs and time relax them so they stay in place?
thanks for any input
Old 05-25-2007, 10:47 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Those are pretty skinny springs so should bow a bunch when you put the full weight of the Comet on them. They should settle out just right.
Old 05-27-2007, 01:21 PM
www.1965comet.net
That's what I was hoping to hear...I played with a Jack under and the weight of my friend holding down the chassis and as I applied pressure...the springs moved the shackle backwards.
thanks
g
leaf springs 49dream Suspension - Brakes - Steering 5 01-25-2007 09:05 PM
Rear Leaf Springs ...."Clamping Them?" white66coupe Suspension - Brakes - Steering 12 03-11-2006 12:04 PM
rear leaf springs HD chopped pickup Transmission - Rearend 2 11-05-2005 01:31 PM
rear leafs to stiff 2112jb Suspension - Brakes - Steering 12 10-06-2005 07:29 AM
dearching leaf springs bluechev Suspension - Brakes - Steering 2 08-14-2005 07:16 PM
