leaf springs for a 66 nova.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2005, 01:46 PM
any recommendations on where to get a set of leaf springs for a 66 nova 194cid? it has a mono leaf spring right now. is it better to install multiple or stick with mono?
Old 03-12-2005, 03:05 PM
"70" Cougar's Avatar
Meat-Head Extroidenaire
Well i would say have more then the one like maybe 3 or so, as long as they fit, are same width and go from longest shorter and shortest. With more you can distribute the weight of your car and it won't be so bouncy back there. If you decide to put in new or more leaf springs i would also suggest you put in new bushings on both sides. Your already back there might as well.
Old 03-12-2005, 03:27 PM
poncho62's Avatar
Wiki Edits: 5
The V8 powered Novas came with the multileaf springs. Shouldn't be hard to find a set.
Old 03-12-2005, 05:25 PM
I have a '66 Nova SS,327/350HP. It has single leaf springs. I also had one new in '66. It had single leaf springs.
Johnny
Old 03-13-2005, 04:18 AM
where's a good place to pick up a set? i wont be racing this, i am restoring it. it has a 6 cyl.
Old 03-13-2005, 12:07 PM
IROC100's Avatar
Running on empty
Last journal entry: More pics
Any spring shop should be able to set you up with new springs and bushings. I would keep the mono leaf, its only a six and you won't have worry about different u bolts or different spring widths since multi leafs are narrower.
Old 03-13-2005, 02:34 PM
sc2dave,
Try classicindustries.com or yearone.com
Between the two of them I've found everything I've ever looked for.
Johnny
Old 03-14-2005, 10:11 PM
250.00 for a mono spring from classic?
Old 03-14-2005, 11:03 PM
$249.95 for a set.
Old 12-26-2006, 05:00 PM
boobert's Avatar
Leaf Springs
JC Whitney has a set of multi leafs (3 Leafs) that bolt right up to a mono leaf perch. I just installed them on my 67 Nova bolted right up.
Old 12-26-2006, 07:20 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Did the milti leafs raise the ride hieght?
Old 12-26-2006, 07:29 PM
boobert's Avatar
leaf Springs
I'll let you know in a couple days, I just got the rear end in today but still have to install the disk brakes and plumb new brake lines.
Old 12-29-2006, 11:51 PM
Check stevesnovasite.com for nova info and parts new and used. I have found it to be very useful.
Rear Leaf Springs ...."Clamping Them?" white66coupe Suspension - Brakes - Steering 12 03-11-2006 01:04 PM
66 nova springs hotrod66_57 Suspension - Brakes - Steering 6 01-31-2006 11:21 AM
leaf springs and coil overs jhenry Suspension - Brakes - Steering 2 11-25-2004 06:45 AM
1962 Nova leaf springs snowman77 Suspension - Brakes - Steering 0 05-27-2004 05:22 PM
moving nova springs inboard La Maquina Transmission - Rearend 1 04-09-2003 06:54 PM
