Leaf springs install - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2007, 06:36 PM
I am ready to install my rear leafs , what is the best, (easiest) way center first then front than rear shackles? Advise, thanks, Dana (My leafs are underneath my axle!!) I do have shocks attached also!
Old 02-17-2007, 06:02 PM
I try to do the front first ... then the rear ( shackles ) and then install the rear end ... Always on GOOD jack stands or supported REAL GOOD
Deuce ... Moderator
Old 02-18-2007, 01:11 AM
DOUBLEDICK's Avatar
Go to hotroders lounge to the thread "55 to 59 chevy truck owners" on the first page is Tom Meyers post.He can help you.I know your truck is older but old trucks are old trucks and the guys love to help other truck guys.I am sorry but I am out of town right now so I dont have acess to my photos or anything else.
Old 02-18-2007, 12:01 PM
tmeyer's Avatar
I Used A Leaf Sprint Kit
39Chevy, Thanks DD. I got a bolt on Kit from TCI for my '57 pickup. It is a bolt-on kit. The only welding is on the axle pads once you set the pinion angle. I used a 8.5" gen 2 camaro rearend that I rebuilt, put in a posi ,and added 373 gears. You can't get any easier then this setup.
I used The Right Stuff rear disc brakes. This is a great rear disc brake kit.
Check it out at http://www.meyerbrosrods.com/photos/...k/default.aspx.
72 Nova Leaf Springs Question - Help!! leejoy Suspension - Brakes - Steering 4 11-04-2006 07:21 PM
47 - 54 Chevy Leaf Springs? KernCountyKid Suspension - Brakes - Steering 4 09-11-2006 12:48 PM
what happened with my leaf springs!!! catcherdan Suspension - Brakes - Steering 2 06-25-2006 02:48 PM
72 nova leaf springs joesnova2 Transmission - Rearend 7 06-09-2006 09:12 PM
leaf springs johnnymopar Suspension - Brakes - Steering 1 05-28-2003 05:35 PM
