Leaf Springs Shackle plates. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2008, 07:40 AM
Last journal entry: More painting pics
I am fabricating some rear leaf spring hangers and not quite sure of the loads induced on the shackle plates. Seems like the side loading when cornering could be quite substantial.
I was thinking they should be as short as possible (i.e. just long enough to allow for the back and forth movement of the eye) and maybe 1/4 or 3/8 thick, mild steel.
The hangers I have looked at on production cars use thinner material but have angles built into them. Mine will be flat. Speedway sells some that are 5/16 but aluminum which seemed a little weak to me. Vehicle weight is approx. 3000#. Anyone have any advice?
Old 09-28-2008, 09:22 AM
Herb Adams VSE used to sell shackles that were 2" longer than stock for Camaros, Firebirds, and Novas. I think mine are 5/16" thick, and they definitely are steel. They're quite a bit more meaty than the skinny ones with multiple holes that most people end up using. They're rectangular, with the ends not quite reaching the top & bottom of the bushings, but they didn't seem to affect the handling of the car at all, they just fixed the famous GM leaf spring sag. If I had had to make my own, I'd have cut them to cover the bushings completely, but if H.A. didn't think it was necessary, it probably doesn't matter.
Old 10-01-2008, 07:06 AM
TroyBoy's Avatar
Psychomotors
You can also weld a piece of tubing in the middle of the shackles to strengthen the side loading like I've seen alot of guys do.They sorta look like I-Beams when you get done.
leaf springs for a 66 nova.... sc2dave Suspension - Brakes - Steering 12 12-29-2006 11:51 PM
72 Nova Leaf Springs Question - Help!! leejoy Suspension - Brakes - Steering 4 11-04-2006 08:21 PM
47 - 54 Chevy Leaf Springs? KernCountyKid Suspension - Brakes - Steering 4 09-11-2006 01:48 PM
what happened with my leaf springs!!! catcherdan Suspension - Brakes - Steering 2 06-25-2006 03:48 PM
rear leafs to stiff 2112jb Suspension - Brakes - Steering 12 10-06-2005 08:29 AM
