Which leaf stiffens more...long or short? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2007, 07:13 AM
cboy's Avatar
Last journal entry: Finished
I want to soften up the ride on my new sedan-delivery suspension. To soften the MOST, would I remove the longest leaf spring I can or the shortest?
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 11-02-2007, 07:31 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Everything I've been told is that the shorter ones give the most load capacity. If you look at 3/4 ton pickups they have a very short, but thick, helper at the bottom of the stack.
Another way to think of it is a leaf assembly that is longer, will have a better ride than a car with short leaf assembly.
Of course, you can't just toss all the shortest ones as then the longer ones are not supported as designed.
Old 11-02-2007, 07:44 AM
cboy's Avatar
That one I eliminated from the stack before I started.
Is there an inherent problem with doing this...other than getting the ride TOO spongy? Is there greater risk of potentially breaking a spring if the shorter leafs are not there to support the longer ones? Any other potential problems?
Old 11-02-2007, 08:47 AM
Last journal entry: Journal Update
I am in the same boat with my 50 Chevy Pickup. I replaced the rear leafs with brand new old stock ones and rebuilt the front leafs. The ride I have now is a kidney buster. I am attempting to do the same thing. The rear has 9 or 10 leafs in the back and there are 8 in the front. I have talked to several old timers who have done this in the past. The way it was explained to me was the same thing that was posted before. Long gives you the softer ride, short giving the support. So it's a matter of taking some of the shorter ones out but leaving enough for support. I have also heard to take out every other leaf till you are down to the short ones, then those you can omit or add for height The very shortest one is just for height. It's a matter of playing with it to get it the way you want it. I am guessing that's exactly what I will have to do.
Old 11-02-2007, 09:07 AM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
A lot of the old (mid 50s) ford trucks are lowered in that manner. Removing every other leaf in the spring pack. I did mine that way and hated it. I put it back to the stock height.
The ride was too spongy and it hit the bump stops.
Flipping leaf spring cboy Suspension - Brakes - Steering 16 03-05-2007 04:53 PM
Water pump. Long or Short Zeater1 Engine 5 07-04-2005 07:09 PM
Anyone know where to find a '60-'66 nailhead short or long block??? Ravenous Rod Transmission - Rearend 3 02-05-2003 04:02 PM
T-350 Long vs short shaft change zachscc Transmission - Rearend 2 01-21-2003 01:53 PM
The long and the short of it. 57Chevyman Engine 2 02-12-2002 10:46 AM
