leak in 700R4 bell houseing pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2011, 10:30 AM
Can the bell houseing pan be welded it has a small hole that will leak
Old 06-13-2011, 11:48 AM
XNTRCI-T's Avatar
AKA Lee in KC
If you're talking about the dust cover that goes under the flexplate, it's not intended to be fluid tight. Many of these covers actually have vents in them. If oil is leaking from that cover, most likely you have a blown rear seal in your motor. If it a reddish color it is tranny fluid (ATF) and would indicate a blown front seal on the tranny.
700R4 leak - see photo loafing1 Transmission - Rearend 5 09-10-2010 04:23 PM
700R4 Trans Pan Leak happydad Transmission - Rearend 4 08-21-2008 03:16 PM
700r4 leak Craig legacy Transmission - Rearend 1 04-23-2008 07:11 AM
Small bell housing 700r4 eliotmansfield Transmission - Rearend 2 07-26-2007 08:12 PM
700r4 pump leak Gassman Transmission - Rearend 3 03-21-2004 03:52 PM
