Leak from diff. to axle tube? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2005, 11:27 AM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Is there a fast, cheap or easy way to fix a small leak from the axle tube to the differential in a GM 10 bolt? I got to looking at my '78 Monte Carlo axle and found a small leak from the tube. So far it has just "puddled onto the axle tube, not onto my floor. The car is in storage now and has not been driven in over 5 years. I'm not real sure if it is from a seal, because I've never tore an axle apart. I just do know that I will not let it keep leaking out and eventually get bad enough to drip in my driveway. So, what's the solution? Weld it?
Thanks in advance, Chet.
Old 11-20-2005, 11:37 AM
steve t's Avatar
ex biker, now hotrodder
clean the area, put some j b weld on it
Old 11-20-2005, 11:42 AM
schnitz's Avatar
Wiki Edits: 54
That sounds almost too easy. Have you got any idea why it would leak in the first place? And, where do you find that magical number for the i.d. as to what it really is. I spent $50 for this axle about 3 months before I quit driving the car. I was told that it came from a Camaro, but I'm not real sure about that.
Thanks again, Chet.
Old 11-22-2005, 08:02 PM
Chet, I'm kind of confused; did you just install this rearend before you parked it or did you install it long before? Axle tubes don't normally leak from the center section unless it has been hit . I would check this rearend out carefully before I spent a lot of time and money on it.
Old 11-22-2005, 10:44 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I've got an 80 and it leaked too. I have seen several that have leaked between the axle tube and the center housing. The toe in and camber of the rear end on my 80 beater is horrible, wearing the rear tires, but still running after 240,000 miles.
Ideally you would weld both tubes and straighten the housing.
There's no pressure inside there. Just clean it off with a wire brush and brake cleaner, air dry it with an air hose and do a nice job of spreading black rtv over it, forcing it into the groove well and wiping off the excess. If there is enough rtv in the groove to see it, that is all it takes. It works.
Old 11-23-2005, 04:26 AM
schnitz's Avatar
Wiki Edits: 54
I put it in about 3 months prior to quiting driving the car. It's funny to me that you mention it being hit, though. The old one didn't leak after a ditching well over the posted speed limit. You got me thinking that the frame is twisted up worse than I thought. That's not a big deal, I have another frame waiting, and a different axle as well. I found one that has the factory ratio in a local yard--rust covered, but non leaky. The only reason I swapped the factory one was the car had a low growl whenever I made a slow left hand turn. I figured it was the axle. Turned out the trans blew out--after swapping the axle out 2 days prior. I never did learn about why it blew.
Anyway, I'll be cracking soon on this "new"axle, and will be prepping this one to make sure it doesn't leak. Thanks for the input.
In a while, Chet.
Old 11-24-2005, 12:06 AM
Those tubes are only pressed in, and will sometimes leak a bit without any previous damage. They can also slip around in the housing and make the car feel a little squirrelly on a hard shift. Best bet is to get the tubes welded to the housing.
Rear Axle Leak Ford 9 inch zonk Transmission - Rearend 5 08-19-2005 06:30 PM
In search of undrillled dropped tube axle kayak Suspension - Brakes - Steering 2 06-30-2005 06:48 PM
Axle Tube Number ID Help Morex52 Transmission - Rearend 2 01-08-2005 08:00 PM
Filler tube leak Deadtemple Transmission - Rearend 2 10-08-2003 06:39 AM
1950 F1 Brakes on new tube axle whitewallcheaterslick Suspension - Brakes - Steering 4 12-26-2002 09:19 AM
