Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Leak at front of Muncie transmission
Old 09-03-2006, 03:42 PM
HotRodMan HotRodMan is offline
It is very difficult to tell exactly where the leak is, but I have no sign of a rear main oil seal leak (No oil on the back of the engine). I have gear lube all over the inside of the bell housing, and bearing retainer,and it has even gotten on the clutch disc.
If the counter gear were leaking, wouldn't run down the front of the transmission to the ground without getting into the bell housing?
Is my best chance of fixing this to replace the gasket behind the bearing retainer?
