Leak at front of Muncie transmission
I have the engine out of the car, the Muncie 4 speed transmission is still in the car. It leaks fluid up front.
Is this just a matter of replacing the gasket behind the bearing retainer, apply a little sealant, and torque the bolts, or is it more complicated than that? None of the parts stores have this gasket. Does anyone know where I can get one? |
Bryan |
It is very difficult to tell exactly where the leak is, but I have no sign of a rear main oil seal leak (No oil on the back of the engine). I have gear lube all over the inside of the bell housing, and bearing retainer,and it has even gotten on the clutch disc.
If the counter gear were leaking, wouldn't run down the front of the transmission to the ground without getting into the bell housing? Is my best chance of fixing this to replace the gasket behind the bearing retainer? |
Leak
My bet is that the retaining nut is installed backwards... About 25 % of the muncies i take apart that were rebuilt before have the nut on backwards.... The nut is actually a oil slinger arrangement that is designed to vent the transmission and keep the oil from running out the bearing retainer...
I have the gaskets and parts in stock if you need them...PM me if you need a phone number to call Keith |
K-Star is right on, that has been my experience also. There probably is not a Muncie in existence that has not been gone into. Most have been worked on by amateurs. The majority of leaks I have found were the result of the nut installed back wards. I even found one that was overhauled in a Chevy garage by an experienced trans man after it came back for a leak.
Vince |
| Hoods not shuting all the way | 74_Chevrolet | Body - Exterior | 5 | 09-01-2005 07:10 PM |
| Swapping a Muncie SM465 to a TH-350 on a FS Chevy Truck | TL-Iguana | Transmission - Rearend | 1 | 08-22-2004 05:54 AM |
| Transmission Leak on a T350 | tiburon62 | Transmission - Rearend | 2 | 01-30-2004 01:48 PM |
| GM Front Diff. Reliability For Full Time Use. | M&M CUSTOM | Transmission - Rearend | 4 | 10-31-2003 05:36 PM |
| Hotrodders Knowledge Cluster: Front Clip Installs/Subframes/Frame Swaps | Jon | Suspension - Brakes - Steering | 0 | 10-12-2003 03:56 PM |
