Leaking 1940 Ford Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2006, 06:34 PM
I am trying to help my father solve a problem with his 1940 Ford Coupe. He told me that transmission is leaking and it is a well know problem with this transmission. Any help would be appreciated.
It is leaking from the rear.
Old 05-10-2006, 09:59 PM
Leaking from where???
Stick?
Overdrive?
Fornt, rear or side covers...
Give us a little more help......
Old 05-10-2006, 10:13 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Yes it would help if we knew where the leak was since we cannot see it.
Old 05-10-2006, 10:19 PM
1940 Fords are 66 years old now ...
And they leak ... and then ... leak some more ...
I drove this one for many years ... until 2005 ... when I sold it ...
I rebuilt the transmission and it still leaked ... less to be sure ... but it still leaked ...
I have been told they leaked NEW ...
I put new shift seals and a new side cover gasket on mine and it slowed the leak way down ... but it was NOT the best seal area on the shift lever seal areas ... they were just worn ... 60 plus years will do that
1939 Ford transmissions leak WAY less ... because they are a top shift ... and the 40 is a side shift ...
1939 Top shift
1940 Ford style side shift ...
Old 05-10-2006, 10:42 PM
Most V8 Ford parts suppliers have this kit ...
About $60 ...
This should Slow down or fix the leaks ...
1940 ford sedan EGOP8 Introduce Yourself 3 01-08-2006 10:26 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 06:29 AM
Help me help my dad! 1940 ford parts needed scoffmanco Interior 1 11-09-2003 08:58 AM
Ford Transmission Swap Ranger2346 Transmission - Rearend 1 10-23-2003 09:43 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
