Leaking 45* inverted flare brake line - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2010, 01:27 PM
001mustang's Avatar
My OEM inverted flare leaks very slowly.
I noticed some rust on the OEM steel inverted flare face.
I am considering bead blasting the rusty inverted flare face.
Would prefer 45* conical sanding/polishing cone; I don't own one.
Any advice for sanding or polishing the conical 45* steel inverted flare?
Old 10-25-2010, 06:58 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Yeah... DONT. you will remove metal and weaken it. Just cut it off and reflare it. Flares are easy to do. If you have to replace the whole line so be it. You should have enough slack to cut a little off and reflare it.Dont cheap out on your brake system.If there is rust inside the flare it may have a crack in it. Take a good look at it just to see.
Old 10-25-2010, 07:33 PM
001mustang's Avatar
The line looks clean past inverted flare seat as far as I can see.
Some rust took hold where inverted flare faces interface.
If it doesn't clean up I will replace line.
Old 10-26-2010, 06:44 PM
68NovaSS's Avatar
Wiki Edits: 9
Keep in mind brake line flares need to be double flares, I don't believe most run of the mill flaring tools will make double flares.
Old 10-26-2010, 08:53 PM
302 Z28's Avatar
Nope and even some so called "double flare" cheap tools also have a real problem with it. A quality double flare tool is rather expensive. I sincerely hope this guy is not using single flare on his brake line.
Vince
Old 10-26-2010, 09:00 PM
001mustang's Avatar
Vince
Not likely.
Old 10-29-2010, 02:41 PM
rwruther's Avatar
Last journal entry: new wires for the hot rod 39
I bought one of those cheapo double flare tools and did ALL my brake lines on my 39. I had to learn the hard way, it's not easy to get a good flare, it's HARD to get a good flare. Any little bitty mark or any off angle at all, a bur, anything! And the joint leaks! I HATE my cheapo flare tools, but it's all I have. Everybody I know just buys the store bought lines and bends them to fit. ...just my 2 cents
Old 10-29-2010, 02:46 PM
001mustang's Avatar
Thanks,
That succa hasn't leaked a drop in days since I repositioned top.
I noticed new top gasket has no ribs but old one did.
I will continue to watch it.
Brake Line Guidance... V8 Super Beetle Suspension - Brakes - Steering 7 03-09-2010 01:40 PM
Brake Line Flare Nut advice needed......... scotzz Suspension - Brakes - Steering 13 01-20-2009 04:43 AM
Leaking Line ?? 1957chevyrod Suspension - Brakes - Steering 1 11-18-2008 06:29 AM
Brake line fittings tubbedz Suspension - Brakes - Steering 14 05-16-2008 12:04 AM
Brake line maintenance Dave57210 Suspension - Brakes - Steering 17 03-04-2007 12:54 PM
