Leaking booster-Holley Carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2008, 08:20 PM
corvette77's Avatar
Giddy Up
Just wondering if anyone can make a suggestion as to why I have one, only one booster leaking fuel on the primary side ? The carb is a Holley 750 dbl pmp. sitting on a 350 Chev with trick flow heads, Edelbrock air gap intake, the vacuum gauge is reading at best 9hg, I have checked fuel pressure(about 5.5) as well I have checked and cleaned the fuel filters, re-adjusted the float to the proper level and still a leak out of one booster ? Im running a 6.5 pwr valve, I have experimented with a 5.5 and a 4.5 to see if anything worked, still leaking. The primary jets are 73's. The motor seems to idle pretty good at around 900-1000 rpm but I know this leaking booster is not right. Any suggestions would be great.
Old 10-01-2008, 10:17 PM
406 bug's Avatar
9.82 @ 139mph
Sounds like fuel level in bowl- replace neddle/seat?? may be sticking open.
Old 10-02-2008, 02:23 AM
SSedan64's Avatar
Odd to just have 1 side leaking? May have trash in the other booster circuit plugging flow. But does sound like a leaking seat or sticking float. Torn float seat or trash holding it open.
Holley (ProForm) Carb Problem leejoy Engine 29 04-01-2011 11:36 AM
Holley Carb Gas Leak 64Joker Engine 21 07-18-2010 02:28 PM
Holley 4777 carb. questions. TVR383 Engine 16 07-05-2009 02:23 PM
Demon or Holley Carb for 306 Ford? Dino Boreanaz Engine 10 12-09-2006 06:04 PM
edelbrock vs. holley carb Super Chevy Engine 43 01-21-2006 09:55 PM
