Leaking brake fluid - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2013, 08:34 PM
Leaking brake fluid
I've just run all my brake lines (steel) and find that in some places brake fluid is leaking between the fitting and the steel line. It seems as if the flaring is corrupt. I've loosened the fitting and retightened it as far as I dare go. Still leaking. Replaced some lines in question and connectors and it still leaks. Is there something I'm missing or is there a trick to doing these lines. These are new standard ready made lines. Any thoughts would be greatly appreciated.
Old 10-24-2013, 05:48 AM
Irelands child's Avatar
To take Denny's response a little further
Angles - AN fittings are different then SAE at 37 vs the SAE at 45*.
Tubing - over tightening can split that folded area (the doubled up area). Then there is the possibility that the tubing is defective. Most of it is welded and will occasionally split at that weld - then the possibility of just crummy material from a far away country is always there.
My fix is spend a few bucks, buy an inexpensive bender and a pretty good double flare 'kit' along with a tubing cutter plus some standard tubing from a good supplier such as NAPA and make up your own. Those so-called lengths really don't fit most places on a street rod and are often used as a source of material only. You will then be able to fit those lines better plus know they are most likely done correctly
Irelands child
The Following User Says Thank You to Irelands child For This Useful Post:
27Tall T (10-24-2013)
Old 10-24-2013, 06:52 AM
Banned
X2 on that, i always bend and double flare them myself. Never had a problem this way.
The Following User Says Thank You to killeratrod For This Useful Post:
Old 10-24-2013, 08:07 AM
Wiki Edits: 27
thread sealant
In the 70's Ford used a drop or two of a thread sealant on the master cyl and combo fittings on Fairlane or Mustang. I don't remember what the spec was but it was in the little red locltite looking bottles .
The Following User Says Thank You to timothale For This Useful Post:
Old 10-24-2013, 08:35 AM
I had the same leak problems when I was plumbing a new brake system. I replaced all the lines a least once with no luck. Then I put one down on my work bench next to a magnet by chance, and the fitting was attracted. Come to find out, the lines I bought from NAPA had steel fittings plated with brass. I purchased new lines with solid brass fittings and the problem was fixed.
The Following User Says Thank You to T Evans For This Useful Post:
Old 10-24-2013, 08:52 AM
Coated steel fittings are standard. I would not use brass(copper with zinc added) on brakes as it can work harden and fracture. Even worse is the potential for galvanic corrosion between different metals then the failure.
Irelands child
Old 10-24-2013, 10:58 AM
techinspector1's Avatar
Wiki Edits: 326
I use insulated Adel clamps for securing any type of line to the car.....
Steel Adel Clamps
Your local Ace Hardware will usually have a good supply of different sizes.
The Following User Says Thank You to techinspector1 For This Useful Post:
Firebird leaking rear brake fluid. bigdog7373 Suspension - Brakes - Steering 3 02-19-2011 06:39 PM
stall leaking fluid no name Transmission - Rearend 4 10-22-2007 07:43 PM
fluid leaking out servo... bstm23 Transmission - Rearend 3 01-22-2004 05:41 PM
Leaking transmission fluid from the starter???????????? mk231975 Transmission - Rearend 5 12-08-2003 07:24 PM
th400 leaking fluid v8s10 Transmission - Rearend 4 03-16-2003 12:57 PM
