leaking brake hose - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2005, 10:44 AM
Toms57's Avatar
Last journal entry: More Engine pics
leaking brake hose
I am currently installing disk brakes on my 57 chevy. I am getting a leak at banjo bolt and hose. I installed washers but it still leaks. Anybody got any Ideas.
Thanks.
Old 11-20-2005, 02:01 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
are you using BRAND NEW copper colored washers???
regular washers will not work
SR66
"SlowRide66"
"Illegitimis non carborundum"
Old 11-20-2005, 02:13 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Yep you need new washers. The copper ones are the best, but I have used some of the new aluminum ones and they worked ok. Be sure that the mateing surfaces on the banjo fitting and on the caliper are good and clean.
OEM brake hose recommendations powderbill Suspension - Brakes - Steering 1 01-14-2005 08:57 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Wound up brake hose 71gtx Suspension - Brakes - Steering 2 01-07-2004 06:17 PM
front disc brake leaking Lowgmc83 Suspension - Brakes - Steering 2 12-20-2003 08:48 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
