leaking carb flange gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2005, 03:44 PM
New Member
my carburator gaskets are leaking. the squarebore gasket that seals the phenolic spacer to the manifold is leaking. i just ran it and its wet. whats a good trick to seal this up? please advise.
silicone + gasket or
dry gasket or
just silicone
Old 08-09-2005, 03:58 PM
sbchevfreak's Avatar
Licenced Automotive Technician
just silicone
Silicone & gas don't get along.... I have had good luck with a new gasket and some aviation sealant.
Old 08-09-2005, 04:45 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
They guy that rebuilt my carb told be to put tranny fluid on my gaskets to swell them up before I installed them.
Haven't tried it yet.
Old 08-09-2005, 04:47 PM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
Vaseline will help seal a gasket if applied thinly.First thing is make 100% sure that all the old material is removed from the carb base and the intake.Check for flatness also. Fuel leaks are more common to come from a worn throttle blade shaft bore though.Check to make sure that i snot worn any and allowinf fuel to seep through.
Old 08-09-2005, 06:24 PM
New Member
whilest i was inspecting my fuel bowls i decided to do the bowls gaskets. i noticed that the hole for the accelerator pump had all kinds of flash. the hole in the bowl casting. on the inside diaphram side. is this normal?
Old 08-10-2005, 04:49 AM
RCastle's Avatar
Holly Carb? They are a cast design,so they will have flashing and be porus.The flash shoult be removed if it can be recahed easily without gouging anything.
carb gaskets...poor idling...holley 4160 oldmako Engine 4 07-25-2010 10:58 AM
Holley 4777 carb. questions. TVR383 Engine 16 07-05-2009 02:23 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
I need help finding gaskets for Carter Carb.... onebadmerc Engine 2 11-29-2004 02:13 PM
rochester 4 jet carb, rich Walker Engine 2 07-13-2003 09:42 AM
