the o rings are available at the hardware store too. Howeverv the piston cups are not as easy to get. If lucky you can find one at the local jack repairhouse. I did the HF low profile. Made in china but uses jap piston made of better steel then china., about $80. Amwerican made for daily use about $400. U do the math.
saw some jack oil with stop leak abilities on truck u today. try to find some try it out.
I've used the stop leak, and it worked for me!
| Recent Garage - Tools posts with photos |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| DANGEROUS Leaking Pro Products Fuel Filter | Bart | Hotrodding Basics | 3 | 06-25-2008 06:24 PM |
| Centerline 2-piece wheels leaking, what's the best sealer? | F&J | Hotrodding Basics | 7 | 06-13-2007 04:43 PM |
| HELP QUICK Electric Fuel Pump Leaking | 66 T-Bird | Engine | 4 | 06-06-2005 06:26 AM |
| th350 leaking only under load | justspeed | Transmission - Rearend | 6 | 10-31-2004 03:18 PM |
| th350 leaking only under load | justspeed | Transmission - Rearend | 10 | 10-06-2004 09:03 PM |
