Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 05-07-2008, 04:13 PM
cares cares is offline
Leaking frost plugs ??
On a 350 sbc engine....... is there a frost plug on the rear of the engine block?
I just installed a new engine and after starting it and the radiator gets to 180 degrees there is an antifreeze leak that drips between the engine block and the bellhousing. The drip is coming from the lower dust shield area.
What would be the source of the leak? After the engine cools down the leak is gone..... I'm stumped....
Any suggestions to solving this problem would be appreciated.
Thanks
Old 05-07-2008, 04:26 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Is There Anybody Out There?
re: Leaking frost plugs ??
yep there are 2 freeze plugs in the rear of the block, sealant should be used on them to ease installation and prevent leaks. There could be a crack, but would be rare on the rear of the block. Are you certain the intake doesnt have a leak in the rear water ports thats running between the bellhousing? If it is the frost plugs, you maybe able to use a coolant sealer like bars stop leak or the like, but to fix it correctly, you'll have to pull the engine. It likely only leaks when warm due to the pressure in the cooling system.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Leaking frost plugs ??"
Cam Frost Plug Leaking rcm800 Engine 3 02-29-2008 06:49 AM
Frost Plugs sexypizzaman Engine 7 06-04-2007 02:31 PM
Cam Bearings and Core Plugs (SBC 350)89 gandl2123 Engine 15 03-26-2007 02:06 AM
DO THEY MAKE "CYLINDER HEAD BRASS FREEZE PLUGS ? SCHOONER Engine 9 10-29-2006 08:25 PM
Rant: Bosch Plugs Cost me $300.00 Rolm Engine 7 07-22-2004 08:50 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
