leaking gas tank on 49 pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2005, 06:28 PM
I have a 49 chevy pickup with the tank in the cab. The 1/2 line that
come out of the bottom is leaking ever so slight. It leaks at the base where it goes in the tank. Does anyone know what I can use to seal it up.
If any one can help me on the leak problem, I would be thankfull
I might even consider replacing the tank at a different location other than in
the cab. If anyone has done this where did you locate the tank and where
did you get the tank.
Thank U
Marcus
Old 03-26-2005, 08:29 PM
poncho62's Avatar
Wiki Edits: 5
If it is leaking where you say, I would sujest replacement. You want a cab tank to be well sealed and no leaks. I have a cab tank in my 51 Ford with no problems....of course, I don't smoke either.
Most times they relocate the tank to the back between the frame rails. You may find something to fit, but a custom tank is the best way to go.
Old 03-27-2005, 06:06 PM
NDtruck's Avatar
'58 Longbox Fleetside
I agree on just replacing the tank.
For tank ideas head over to
www.chevytalk.com
www.stovebolt.com/
www.chevyduty.com
This forums have tank relocation questions for the AD trucks pretty frequently so you can get some ideas and feedback for your specific model there.
I know I've seen camaro, mustang, and I think blazer tanks used in the rear of the frame. Besides the custom made tanks that is.
Chevy duty should sell replacement tanks too.
Old 03-27-2005, 07:58 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
/\agreed. If you want to keep the old tank, have it repaired (make sure theres no gas fumes or you'll kill yourself- SERIOUSLY!) and use it to run engines not yet connected to a "real" fuel system in a car, tractor, etc. if it is relatively small.
Old 03-28-2005, 01:20 PM
Tazz
PM me..I have two of those tanks
Where in Ohio are you? I'm in Amherst Ohio up near Cleveland and Lake Erie.
Tazz
Rat Rods Rule!
Old 03-29-2005, 08:49 AM
Dave E Shank's Avatar
Marcus
I had a 1948 Chevy pickup and the tank leaked. I bought a Tank Sealer Kit from Eastwood and it solved the problem. But the 48 tank was located under the bed not in the cab. Sealer kit should work or look for a 48 tank, there was plenty of room under the bed. GOOD LUCK DAVE
Old 03-29-2005, 09:42 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Like Dave says, those rubberized tank sealers are great. Will permanently solve your problem.
The option I took on my '53 King cab was to move the tank to between the frame using a 70s-80s Chevy 1/2 ton 20 gallon tank. See here.
Torino wont stay running 79firebird350 Engine 4 05-20-2004 12:38 PM
Gas Tank .... problems 63novawagon Body - Exterior 1 04-25-2004 11:26 AM
Rear gas tank conversion on 80 chevy pu williambartram General Rodding Tech 5 09-18-2003 11:21 AM
'49 Chevy PU Gas Tank Relocation hiimed Engine 11 02-04-2003 02:50 PM
