leaking head bolts SBC 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2011, 07:12 PM
itsandre's Avatar
Hey all, me again. Well as some of you know I got my engine running. Unfortunately I have some fluid leaking along the bottom edge of one of the heads where it sits on the block.
At first I thought it was oil but now I'm pretty sure it's coolant. I determined this by removing the valve cover and exhaust manifold and wiping the wetness with a clean paper towel and it's not alot but it's the color of greeninsh as oppose to clear like oil which I dabbed a little from the rocker assembly to compare.
I did use sealant on all the bolts but not alot. I just put it on the threads. Now what I need to know is should I remove all the bolts and add more sealant? If so, do I do this one at a time or should I remove them all so I re-torque in correct sequence?
I'm not seeing any evidence of burning coolant out of the exhaust so I don't suspect the longer bolts are a problem. I do see wetness around the shorter exposed head bolts along the lower edge.
I hope I am giving a good description of the problem to be as clear as possible.
Have other questions with other issues but this is the most concerning.
Old 02-21-2011, 08:21 PM
bigdog7373's Avatar
Of course it's fast
I would try retorquing them to make sure u didnt miss one. Has the coolant level dropped at all?
Old 02-21-2011, 08:28 PM
ericnova72's Avatar
More for Less Racer
If you do need to reseal them pull them, reseal them and retorque them one at a time, so that you don't chance losing the head gasket seal.
Use either a teflon paste plumbers seal or RTV silicone, but don't mix the two. Teflon tape is not good to use, so don't try that.
Old 02-21-2011, 09:53 PM
Daily Grinder
Wouldn't the ARP sealant help in this situation?
Stumped on leaking head bolts redride Engine 16 05-05-2009 03:20 PM
head bolts or head studs? head gaskets? thefloyd1973 Engine 9 07-04-2008 10:25 AM
BBC head leaking coolant. 71javelin Engine 5 12-16-2006 09:31 AM
oil on head bolts and head gasket bullheimer Engine 7 05-25-2004 05:50 PM
leaking head studs!!!! nastynova Engine 4 06-21-2003 08:56 PM
