leaking head studs!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2003, 01:19 PM
nastynova's Avatar
Angry leaking head studs!!!!
I've built a couple motors...changed heads on several...and always used good ol trusty silocone to seal the head bolts from the water passages...with no problems... my latest build up I used the liquid teflon and now I have several leaks...tracks down the side of the block from several studs... best guess, the ones under the valve covers are most likely leaking too...but before I tear it down... what could I have done wrong...everthing was clean...anybody have any insight before I go back to good ol silocone...
Thanks
Nasty
Old 06-21-2003, 03:31 PM
Bumpstick's Avatar
Hammer and a torch
Teflon is not really a sealer... Its a lubricant to help with the threads on pipe or bolts to achive the proper torque or engagement... I use either Permatex "right stuff" or just permatex #2 or "aero seal" on head bolts... I would drain the block via the plugs if they can be removed...? I always put drain valves there too... Then remove and reinstall to proper torque each bolt 1 at a time... This should keep the head gasket seal intact...
Old 06-21-2003, 06:33 PM
nastynova's Avatar
what i used was permatex sealant with teflon...was told it was the stuff to use....I may try the one at a time senario...another 60-70 bucks to re-gasket it...
thanks
Old 06-21-2003, 07:26 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Drain the block and radiator. Start with the correct torque pattern and remove one bolt at a time and reseal and retorque. Mainly you only have to do only the ones in the water jacket in the middle and all across the bottom.
I had to do it one time before.
Dont forget to change the oil.
Luv the smell of NITRO in the morning.
Old 06-21-2003, 07:56 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Redo the studs in the water jackets,likes been said.And reseal,
I`ve used gorilla snot for years,ever since I worked at a chev dealer. It`s always worked for me. Good Luck;
Troy;
