Leaking Line ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2008, 01:08 AM
Leaking Line ??
Bought a new brake system for my 1957 chevy was drum in front, went disc. Well the brake line to the caliper is leaking. Thought it was the washers. bought new ones samething happened. Leaking from the washers again. Wondering if the caliper is bad or the line ? Anyone else have a problem like this ? Anyone know what i can do to stop it or do i have to get a new caliper and brake line ? Thanks for any info
Old 11-18-2008, 07:29 AM
poncho62's Avatar
Wiki Edits: 5
Sounds like one of the mating surfaces is not flat. I would complain to who you bought then from. ..........
Could It be my Fuel Tank / Fuel Line? 10mikeymike Engine 4 09-17-2008 03:25 PM
Anyone ever had a line lock fail and degrade braking? sizemoremk Suspension - Brakes - Steering 7 09-22-2006 03:13 PM
th350 leaking only under load justspeed Transmission - Rearend 6 10-31-2004 04:18 PM
Body Line Man586 Body - Exterior 6 08-20-2004 09:24 AM
