leaking oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2011, 10:24 AM
leaking oil
I have a 350 SBC with new edlebrock aluminum heads. New valve coves ahce large breather vents on both sides. Left side is blowing oil had out the breather vent under hard accelleration. Valve covers do not have the baffle installed.
Will this fix the problem or is something else going on??
Old 09-12-2011, 10:41 AM
SSedan64's Avatar
You do need the Baffles under both Breathers. A PCV on one side would be a better setup.
Pinion seal on 8.2 10 bolt rear end leaking, replaced still leaking?! artillerystevens Transmission - Rearend 6 04-10-2011 04:57 PM
leaking t- 350 ckup54 Transmission - Rearend 9 05-31-2010 12:26 PM
02 f 150 leaking oil woodmanscott@hotmail Engine 8 02-05-2009 09:57 PM
Leaking oil... Magnus_Jager Engine 0 04-09-2004 11:46 PM
Well`s still leaking. DoubleVision Engine 0 12-12-2002 09:19 AM
