Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 05-02-2008, 01:32 PM
Will H Will H is offline
Leaking Quadrajet
Where exactly is the hole in a quadrajet that emties the bowl and what kind of epoxy do I use to fix it?
Old 05-02-2008, 02:33 PM
F&J F&J is offline
re: Leaking Quadrajet
They are called welch plugs. plugs that were installed after machining some passages during manufacture. Pull off the throttle base plate to see them.
Sealer? I need to know as well. Maybe do a search here for quadrajet plugs?
Old 05-02-2008, 02:57 PM
ortamenxs's Avatar
ortamenxs ortamenxs is offline
Avoid the Gremlins.
I fixed one of these a month ago for a friend that wanted a good sealer. I took J&B and made a patch let it sit for eight hours, then took my power stripper, a 1100 degree hair dryer and went over a few times, then I took seal all and put some on my finger and wiped it all over the edges, so far has fixed his problem, but I'm sure there is a more professional way to do it
Old 05-02-2008, 04:49 PM
sprecher48's Avatar
sprecher48 sprecher48 is offline
Oddo nut
 sprecher48's barnstar
Location: sunny south(maybe rainy,haven't looked outside today) florida
\re; leaking quadrajet
Try a product called "Marine-Tex". It has always worked aces for me and will even repair a cracked diesel tank at sea.(not an ad!!!!!!!) Tom
Old 05-02-2008, 04:50 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Is There Anybody Out There?
A trick to the trade I learned on these after epoxy leaked countless times is to simply restake them without using epoxy, and it worked every time. Strip your Q-jet down to the bare body, and you'll see the extended away from the body well plugs, take a punch and a hammer and restake them in the middle. Then set the body on a 5 gallon bucket, fill the bowl with fuel, and you'll find the leaks are gone. Other times, there are other plugs as well in the Q-body you'll find that leak also, you can do the same 5 gallon bucket trick before you restake them to locate every area of possible leaks.
Old 05-02-2008, 04:53 PM
sprecher48's Avatar
Oddo nut
re;leaking quadrajet
good advice,I used the same trick on solex carbs on vw bugs for many years.Tom
Old 05-02-2008, 08:43 PM
Thanks to all of you for the help. This will be "An all new adventure" for me. It's on my wife's Pontiac and it must be done flawlessly. I've never had a Quadrajet off the intake. Thanks again.
Old 05-03-2008, 07:24 AM
Jmark's Avatar
Jmark Jmark is offline
HR moderator dude
There are two sets of plugs on a Qjet that are at the bottom of the float bowl. One set you can see in the picture below. They have the green epoxy on them. These are were two different passages are drilled to feed the primary metering rods/venturies. They are pretty small plugs and sometimes leak or fall out. These are the only two that, when loose, can leak into the engine. (There are some old carbs that actually had that part open but you won't see many like that.)
There are two more much larger plugs that plug the passage intersections that join the secondary jets/metering rods to the float bowl. Nine times out of ten, these plugs are sealed by the base plate, as you can see below. Even if these plugs get loose, the leaking gas has no were to go.
I've used JB weld in the past and it has softened up and fallen off for some reason. Maybe I didn't let it cure long enough. It used to work fine. Maybe try the marine stuff mentioned in a previous post.
Mark
Time is short! Speak your mind, speak the truth!
Old 05-04-2008, 08:38 PM
Frank Valentino Frank Valentino is offline
firedome
leaking Q-Jet plugs
If I remember correctly, Dorman Automotive Hardware made a plug kit for this problem (which has occurred since the first carb came off the line in the 1965 model year). I don't know if they still have it but it worked without sealer. The kit also had a small "sponge" which was installed at the bottom, under the well. It worked great.
Good luck!
Old 05-08-2008, 12:34 PM
David Jones's Avatar
David Jones David Jones is offline
Using JB Weld smeared on the plugs (and there are 5) is a great way to assure that they leak again. The numerous heat/cool cycles the carb experiences will have it leaking in short order. The only way to eliminate the possibility of leaks is to drill out the plugs and thread the holes in the main body. Then buy (or make from the correct size bolt) some threaded plugs that fit. Take Marine Tex epoxy and fill the threads then run them home. Done.
Having these plugs leak into the engine is not the only issue. Constantly having an empty float bowl when you crank the car gets to be a pain.
The best way to assure that you've cured the leak is to pressurize the float bowl with some compressed air and put soapy water on your "fix". Just filling the float bowl doesn't always tell the tale. Funny things can happen when you install the carb on the engine and get it up to operating temp.
Old 05-08-2008, 03:24 PM
ortamenxs's Avatar
Avoid the Gremlins.
I've never had luck Marine Tex, always becomes brittle on me after heat and cool cycles, permatex makes a gas/radiator repair stick, you tear off and mix in hand, that has been gold to me, if you can't find plugs that is.
Old 05-08-2008, 04:42 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
JackOfAllTradesMasterOfNo ne
You're corect the Perm stick does work very well. JB makes a similar product that works great to. Especially on gas tanks. Easier to work with if you moisten your fingers before neading the 2 parts together. Mixes better and does'nt stick to your fingers.
Old 05-09-2008, 04:24 AM
fordSR fordSR is offline
Marine Tex is a very good product for some applications, but 160 deg heat and it losses it's ability to bond. I use it all the time to bed rifle actions into the stock and it's great for that purpose. I've used it to glue in the action as well. When it comes time to remove the action, a little heat applied to the action with the wife's iron..........it comes right out. I use an IR thermomitor to monitor the heat on the action. Other epoxy type compounds will do the same thing..........can't take the heat.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Leaking Quadrajet"
Leaking synthetic lubricants 39 chev Transmission - Rearend 2 06-16-2005 07:06 PM
HELP QUICK Electric Fuel Pump Leaking 66 T-Bird Engine 4 06-06-2005 05:26 AM
th350 leaking only under load justspeed Transmission - Rearend 6 10-31-2004 02:18 PM
th350 leaking only under load justspeed Transmission - Rearend 10 10-06-2004 08:03 PM
valve cover gasket keeps leaking! Jmark Engine 13 09-06-2004 03:01 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
