Leaking TH350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2005, 10:08 PM
MEAN_SBC's Avatar
Leaking TH350
I just got the engine and tranny in my brothers 68 Chevelle. The transmission was rebuilt by a transmission shop here in town. I've got the o-ring on the dipstick, but on the kickdown cable, is there supposed to be an oring, or rubber bushing there to keep it from leaking???? Whenever the fluid level get's above pan level, it starts pouring out the front right side somewhere. I'm trying to figure out what it is... Any ideas??? Thanks in advance....
Old 05-14-2005, 10:17 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
there is 2 types i know of
1 o ring
2 a rubber grommet
the o rind type should have a groove
put it in dry(without any thing)
if it goes in really sloppy it the grommet
if its tight then its a o ring type
"SlowRide66"
"Illegitimis non carborundum"
Old 05-15-2005, 12:55 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
IF your detent cable end uses the rubber sleeve seal..... install the sleeeve into the tranny case FIRST. then lube the cable end and push in gently
Old 05-15-2005, 11:04 PM
BTW...ur left headlight is out
where exactly is it coming from on the front right side? the vent tube is one the right side...i had the O-ring off my TH400 come off on the filter and it would spit tranny fluid out of the over flow tube. also...do you have all the gears? like is it moving foward and backwards?
Old 05-15-2005, 11:11 PM
MEAN_SBC's Avatar
Moves fine.... I actually found the problem today. The rubber o-ring seal on the kickdown cable wasn't on it, and when the fluid got to that level, it would just pour out.... Thanks guys!!!
TH350 driveshaft yoke leaking Jmark Transmission - Rearend 11 08-16-2008 12:38 PM
th350 leaking only under load justspeed Transmission - Rearend 6 10-31-2004 04:18 PM
th350 leaking only under load justspeed Transmission - Rearend 10 10-06-2004 10:03 PM
Leaking TH350? frankenvette Transmission - Rearend 2 09-28-2004 06:08 PM
Leaking TH350 Malibu1980 Transmission - Rearend 2 11-07-2003 08:04 PM
